Re: 3 or 4 Blade Prop?
Theoretically there would be no difference in top end speed if pitch and diameter were the same on a 3 and 4 blade prop. However, Four blades adds some drag so in some cases loss of top end (not a great deal) is the trade off over a three blade. On the other hand, a four blade has an advantage during hole shot because of the extra blade. Four blades exhibit smoother operation. Remember though, you cannot compare a three blade of "X" pitch from manufacturer "A" and a four blade of the same pitch from manufacturer "B" and expect exactly the same result. There are other design factors that enter the equation so blade shape, rake, cupping, venting, and material (aluminum or stainless) all have an effect on performance. One prop may work well on one hull and not worth a hoot on another. Testing is the only real way to determine what characteristics you want for your boat. In a nutshell, prop selection is compromise between hole shot and top end. You give up one for the other.
