Re: 2003 Yamaha 50HP Power Tilt and Trim
My new power trim motor is installed and works great. But, did I ever learn some things about power tilt and trim during the process!
First, never "tap" on the motor because it operates intermittently. I discovered when I opened the motor up that I had a spade terminal which was almost non-existent due to corrosion. Had I known this, the fix would have been simple and cheap. I also discovered that the part that appears to be the motor shell is actually the stator. There are two permanent magnets glued to the shell. Tapping dislodged one of my magnets. NOT GOOD!
Second, shop around before buying a Yamaha part. Yamaha prices their parts like they are gold. I was able to find an aftermarket motor at Hardcore Marine for about half list price...a savings of about $200. I was also checking on installing a trim gauge. Yamaha cost is about $130, aftermarket about $25.
Etc., etc, etc.
