Re: 470 heads
Stop beating up on the 470.... They are nice engines... If looked after properly!
Yes, the head is from a Ford 460, as are pistons and rod. I've never seen it but I have been told by someone I have no reason to doubt that if you get the Ford 'Dove II' head you'll get about 250hp from that engine. They were a favourite of the speedway guys for a while in that configuration. Nothing came close for power to weight ratio.
Bond-o, they produced that engine from 1976 to 1989, it all it's various guises. It was dropped when the V6s took over that horsepower range.
Things to like about them : No fan belts, factory closed cooling, water pump integral with camshaft, light-weight ali block, lots of parts common with the 120/140/165 range, quite an economical engine too.
Things not to like : alternator in harmonic balance... that's about it and that was easy to fix.
Chris............
