SuperNova
- Mar 16, 2007
- 1,455
Re: 1989 chevy silverado k1500 autotrans
1- The 1/4 throttle unlock of the torque converter sounds about right, although I am willing to bet you are underestimating how far you are actually pressing the pedal.
2- When you pull it out of O/D into drive it should gain more rpm because you are forcing the trans into 3rd gear instead of just a T/C unlock.
3-The main thing is the correct converter lock up speed, and it should actually lock around 42 mph in 3rd(drive) or 51 mph in 4th(o/d)
4- The throttle valve cable that runs from the throttle body down to the trans should be self adjusting. You lift the clip and allow the cable to retract all the way (it's spring loaded) and then just depress the throttle pedal all the way to the floor--the cable automatically sets itself.
5- If you decide to do a rebuild definitely install the shift improvement/repair kits from one of the reputable manufactures such as transgo, etc.
Stan
on my 1989 silverado k1500 350 automatic over drive transmission when on the interstate and in overdrive if i press the gas over like 1/4 throttle it slips it acts like it kicks down a gear but if i drop it out of overdrive the rpms come up a little bit more. would this be the torque converter unlocking for some reason or do i have bigger problems. i bought the truck with a blown head gasket and high millage but i had a rebuilt (well about 40,000 mile) 350 so i put that in there the trans had a sticker on it saying it was rebuilt and by what company and such on the bell housing and was pretty grease free unlike the old engine. i had never takin it on the interstate with the blown headgasket only around town enough to make sure that everything was functional on the truck. after the swap it took me a bit of messing around with the throttle valve cable to get it shifting like it used to. i mention that thinking maby my throttle valve cable still is not adjusted properly
Stan
