recently acquired a 1988 Mariner 150. Pee hole sputters originally and then comes on fairly strong after 1-2 minutes. Last outing alarm went on intermittent and noticed no water output, shut down. Let engine cool and had to restart 1/2 hour later for short idle speed burst, alarm went from intermittent to solid tone and manually shut down motor w/in seconds.
For a few seconds there was a pretty clear white smoke from exhaust, I believe this to be vapor. Obviously time to change impeller, should I check for anything else, did I damage anything? A person on the dock had mentioned that his motor will shut down to prevent damage, both times I had shut down manually.
Also noticed that awhile past the water coming from the pee hole was quite hot as a new boat owner please confirm this was a sure indicator of time to change. As I have recently been reading threads, it seems 2 years is normal for change.
Also, original owner mentioned they had hit a sunken water logged tree brance and since that time the spedometer cable seemed to read slower than normal, is there a hole where the water pressure measures speed that can be cleared out?
I also find the motor is slightly difficult to start first thing, once started it starts quite well through rest of day. Is the two stroke oil bad, is the octane level high enough, I usually put in 89-91 octane, any and all suggestions appreciated.
