billywhizz
- Nov 22, 2007
- 174
Hi, I have the above carb and engine, all cables are fine, lubed and not sticking, but the problem i am faced with is that there seems to be no range on the carb,ie: 1/8" movement on the control and she jumps from 650 rpm to 2000rpm as you can imagine this makes things pretty difficult when trying to manoeuvre at low speed, not to mention the danger aspect of catapulting my crew overboard!, the engine has low hours and is in good service order, so i have to put this problem down to carb, i also have disconnected the linkage and moved the lever on the carb by hand , same again, tiny movement and it revs too much, should i be thinking of replacing the carb to achieve a more moderate acceleration,particularly as i use the boat on inland waters not the ocean and do not require all this power, or can i get the desired effect with a rebuild kit? or would it be possible for me to change jets in order to reduce the power output?also i have looked down into the carb and i assume that both inlet flaps/valves are supposed to open at the same time and not one before the other? could you confirm this? thank you for your time,
Billy
Billy
