spiker_man
- Nov 8, 2005
- 16
Hi All. I've got a Johnson 9.9 outboard that is missing the Model #/Serial # plate that should be found on the mid-section of the motor. The two rivets are there but the plate is missing. The motor needs some work done on it but without knowing the year I'm sort of screwed. I had bought this used about 6 years ago and I thought this motor was from the late '70's/early 80's but I'm not sure. The only number I can find is stamped on the engine block:
318928-1
My guess is that this is a part number. There are also a ton of patent numbers printed on a plastic piece in the front of the motor, but I don't think that these will help determine the year of the motor. Any ideas on where else I can look to find a model number? Any help/advice is greatly appreciated. Thanks. Paul
318928-1
