I have recently bought a 1978 glasply with a 305 185hp omc 800. It has sat for many years but I have got it running smoothly on muffs. Problem is that the engine overheats before it gets to temp. (160) pukes coolant out of overflow @ about 120-130 degrees. Replaced thermostat but cant see any water movement thru heat exchanger ( not getting a chance since it overflows before it gets to temp). Suspect circulation pump (on engine) or plugged up heat exchanger, exhaust mans. Any tips to narrow or solve problem .. Thanks
