Re: 73 merc. 7.5
OK this is the owner of the 7.5 hp merc. Tested per your procedure. Thanks for the help laddies. The brown wire disconnected from coil allowed spark from the other connected coil. Yea, progress! That says that the brown wire is bad or points are bad. But to get flywheel off requires 3 large phillips head screws to be disconnected. Then nut on top would probably be next and harmonic pully puller used to get flywheel off. Am I correct? Cornell
