Where does the hole on exhaust side of the drive go to?
Not sure of your motor, but some of the big blocks specify a tube instead of a bellows. If I remember correctly, with the bellows the motor can cause a vacuum at the prop (I assume from the volume of exhaust gases) at high RPM and hurt your performance.
MAGNUM BRAVO MODEL EXHAUST RECOMMENDATION
Important: To get maximum performance from Magnum Bravo Models, through the transom exhaust is required. It is recommended that the exhaust bellows on the transom assembly be removed. This is necessary to avoid creating a vacuum at the exhaust outlet in the propellor at higher boat speeds. This vacuum could degrade propellor performance on some boats.
Note: If noise regulations do not allow the use of through the transom exhaust, an exhaust pipe kit (Quicksilver P/N 44266A6) must be installed for the through the prop exhaust. This kit also contains an exhaust tube that is used in place of the exhaust bellows.
I am going to get the tube. Aftermarket ones are just as good I am guessing.
