Re: trim tabs, how big is too big?
Sea Hawk,<br /><br />I am Thomas and I work for Bennett Marine in the Client Service department. <br /><br />Your 23 vessel by our General Sizing Recommendations falls in the 24 x 9 trim tab range, but depending on the Available Mounting Area (determined by starting 3-4" from the chine and measuring to within 8" of the outdrive) you may have to step down in size (22 x 12, 20 x 12, or 18 x 12). So, the next thing for you to check is the Available Mounting Area. In general, the largest trim tabs that will comfortably fit on the transom will be the most efficient, but protrusions (transducers, speed wheels) &/or obstructions can influence your choices. The closer you can stay to the 24 x 9s the better the performance will be for slow speeds and hole shot, just like Boatist stated. Speed capabilities also play a part in your trim tab choice, so please let me know what she can do and how you drive her. Some vessels have plumbing troubles because of their design, but we have a few tricks that will normally cover any situation you run up against. It really is just a matter of looking at the installation and explaining to me your woes. So, take a look at your transom and get back to me with the measurement & speed information.<br /><br />I look forward to your reply.<br /><br />Sincerely,<br />MJ Thomas<br />Bennett Marine, Inc.<br />Client Services<br />trimtabs@earthlink.net
