Haut Medoc
- Jun 29, 2004
- 10,645
Re: Restoring 1974 revisited.
Pretty sure it is on the casting......
..... What about the distributor? I noticed that the 302 and 351 seem to take a different distributor.
That's a good point Boom....351's need a longer distributor shaft due to the taller deck height of the block. Also, the intake manifold is wider to span the larger gap created by the taller deck height.
All OMC 190 hp Ford 302's and Merc 188/888 302's and I assume Volvo too, used the 351 marine cam and 351 cylinder heads that were Factory drilled for the smaller 302 head bolt diameter. To use any automotive 351 head on a 302 you would need to buy a set of special head bolt washers built for that purpose.
Although Glastron may have warranted the motor, they did not build it. It was a Ford factory item.
Believe me, you do not want the added weight and size of the 351 in your Glastron.
