Re: Cobra 4.3L, any good?
It's a Chevy. Basically a V8 smallblock with 2 cylinders chopped off. They used them in Blazers among other vehicles. I have an '89 Cobra 4.3 also in a Four Winns. I have no complaints with mine, runs great and fuel efficient. But not knowing what the reason is for that engine not running, it's tough to give any opinion. Most parts are readily available, certain others that are specific to OMC can be pricey but there are still alot of parts around. Bombardier, the company that bought OMC, has OEM parts available and there are aftermarket companies making parts as well. You difinitely want to check the outdrive also but without the engine running that's not an option. You can spin the propeller by hand and observe the shift assembly to see if it operates smoothly and freely and the prop locks when shifting. Might be a good idea to have someone who knows and understands boats to look at it, even if it costs you some money. You can't be cautious enough when buying a boat that is not operating unless you price it for the worst possible scenario, ie:replacing the sterndrive
