Hi all....
Does anyone know what my top speed should be for a 1992 Capri Cuddy 2052 with a Force L-Drive with a 19C Prop? I took the boat to the lake and was dissapointed with only 19MPH (measured with GPS) with a WOT of 3500RPM.
I tried all trim levels and when I trim up, there is not enough speed to plane out. I can only plain out with the trim all the way down and I only get the above speed/RPM. What gives? In Neutral the RPM's exceed 4500 and the same in reverse. IN forward I get the poor results mentioned above. The bengine idles at just over 1000RPM and fires up with no issues. Does anyone have any advice/suggestions?
What speed/RPM is normal with this boat motor setup? Also I am at at 3500Feet altitude (not sure if this makes any difference).
What prop setup should I go with for optimal performance?
Cheers,
Rob
Cheers,
Rob
