Re: I think my charging system may be dead.....
A very good place to start is to check the battery voltage as described above motor off then motor on. If there is no change see if you can test the input voltage and output voltage at the regulator with the motor running. I am not sure what it is supposed to be. If there is a good voltage in, but not out then your regulator is bad. The way I was taught to trouble shoot electricity is to start roughly in the middle of a circuit. If you are getting what you are supposed to be getting move towards the load (the battery in this case), if you are not then you move towards the source (the generator in this case). Always working near the middle of the known points.
Example:
Components in order from generator to battery.
1.) Generator (Source)
2.) Voltage Rectifier (converts A/C voltage from generator to D/C Voltage.)
3.) Voltage Regulator (takes variable D/C Voltage and stabilizes it at about 14.4 VDC.)
4.) Battery (Load)
This is assuming that the Rectifier and Regulator are 2 assemblies They are regularly one assembly, but it demonstrates below what I meant by working at roughly the middle. If you know that a particular part is a high failure item that is a good place to start and work from there. To start testing you would check the components in roughly the following order.
1.) Regulator voltage in/voltage out (D/C in and D/C out).
no voltage in = move to Rectifier
good voltage in/no voltage out = replace regulator
good voltage in/good voltage out = check connections between regulator and battery.
2.) Rectifier voltage in/voltage out (A/C in and D/C out).
no voltage in = move to Generator
good voltage in/no voltage out = replace rectifier
good voltage in/good voltage out = check connections between rectifier and regulator.
Continue using above technique until you find the source of the problem keeping in mind that it can actually be wiring. It doesn't always have to be a part.
Note about using a multimeter, if you have your multimeter set wrong you may replace a part that didn't need it. Keep in mind that some multimeters only use symbols to label ie a wavy line for A/C, straight for D/C and Omega for ohms. Finally probably the two most important things are safety related. Never use the ohmmeter function with a circuit under power, it can not only fry your meter but with sufficent voltage hurt or kill you and NEVER put your fingers on the metal part of the probe.
As thoroughly as possible you also want to visually inspect all wiring for signs of chafing/shorting or any other defect. Troubleshooting electricity is not hard, but it can be very tedious especially on a airplane. Compared to that small boats are easy. Take care, be careful and hope you find the problem.
Good Luck.
