buckstop108
- Aug 2, 2007
- 67
I did the compression check as instructed on my 1992 85 HP evinrude backtroller and this is what I have.
TOP PORT : 127
BOTTOM PORT : 126
TOP STAR B : 126
BOTTOM STAR B : 125
I checked the spark and I am getting spark on all cyliders. The bottom two plugs are clean with very, very little carbon if any and they are wet with gas smell. The top two very black and not so wet. Now a little history. I first thought I had a water problem and I might have I think I have that addressed. I think I got all the water out of the tank or at least the vast majority of it and added a treatment, starbrite. I added a water separator and new 3/8 lines , changed the filter and clean out the bottom bowls of both carbs. Sprayed them down with carb cleaner and let some injection cleaner sit for a while then flushed out the bowls again. She is still running ruff and sounds like she is missing. She won't stay at idle under 1000 rpms and a lot of unburned fuel still coming from the exhaust. Along with a lot of smoke.
The bottom carb has fuel coming out of the jets and a port that is at the top of the botttom carb. The top carb didn't appear to have fuel dumping out as did the bottom, from the jets or that port. What is my next step before I bring this to a pro?
TOP PORT : 127
BOTTOM PORT : 126
TOP STAR B : 126
BOTTOM STAR B : 125
