Re: Is my top speed right?
i would think so, you need a tach, to see if you are turning the correct rpms. the engine height set correctly, also is the boat holding water in the foam. also speedo's are a pressure guage, pressure is put on the pitot opening, as the boat moves thru the water, they applies pressure to the air in the hose, and is registered on the speedo, a small air leak will effect the reading. also the higher the speed the less accurate that type speedo is.
