Hi I have a Johnson and I had some troubles with it. Perhaps some one will be able to help me out:
BEFORE TODAYS TROUBLES
1. Motor usually starts after a few pulls
2. Does not like going much slower then at the "START" speed
3. When starting it will often stall out a few times, before I get it going for good.
TODAY:
1. Starting like before, stalled a few times.
2. Gave it another pull and heard a "pop" sound.
3. I saw little white solid grease pieces floating around in the water.
4. After that, I could not get a spark or anything.
5. Changed the Spark Plugs, and it started right away.
5.5 Old sparkplugs are very dirty. There is grit on them, and they are wet/oily and dark. When I stuck a wire up the exhaust that is below the water, I noticed a lot of grease on it when I pulled it back out.
6. Took it for a spin.
7. Stall out when I slowed down, and would not start again until I took the sparkplugs out and retighten them.
8. Starts, but takes a lot of pulling to get it going. I also heard the pop again, and saw the white bits of grease in the water again.
9. Get it going again and take it back home.
10. When I tie up, I think the motor is a little warm.
11. I did notice that the motor heats up fast when I idle the motor at a high speed (I can tell but placing my hand under the water output,almost burning)) When I slow the motor down again, the water output cools down again.
12. I also notice how the water is coming out. WHen running idle fast the water stops for a split second every few seconds at a regular pace. When it comes out strong.
Problems suggested to me:
- I have a broken gasket some where.
- The impiler(sp?) on the water pump is partly broken.
any help would be great
TODAY:
