Ok, have a 250 chevy in-line 6.
The motor has an oil leak at the top of engine where oil collects on intake/exhaust.
symptoms:
1. valve cover gasket does not leak. (forced a little air in the pcv valve with my hand over the oil filler and no air escapes.)
2. no oil slinging on the inside of the doghouse.
3. no oil around coupler in back of engine.
4. No pcv valve, only hose from valve cover to spark arrestor.
The only time I notice anything different about the engine is when I have it under power, the engine makes a hot smell. (hot oil smell)
So the question is, where is/could the oil be coming from if not for the valve cover gasket? I am stumped by the whole gravity thing. The oil seems to be coming out while under higher load. (not pouring out, but still coming out)
Thanks for your help.
symptoms:
