Re: My rapido longblock (pics)
Okay, here's the pics from our first day of assembly - we almost got the whole thing put together!
We started at 1pm and finished at about 8:20, with about a half hour dinner in the middle.
Everything went smoothly, with just a few notes:
1) We didn't notice the intake manifold gasket restrictor inserts until the intake was already on (dumb us).. fortunately we don't seem to need any?
2) We couldn't find the proper bolts for a lot of things because I didn't label them properly, so we ended up wasting time finding bolts that fit
3) The rapido block was painted as part of the reman process, and paint and gunk in a few bolt holes caused us to scratch our heads a few times wondering why bolts didn't fit - if you assemble a block like this, I suggest you clean the bolt holes with an appropriate tap first - don't re-tap, just gently clean the holes.
4) There were a few spots of rust on the block after sitting outdoors (under a tarp) overnight - it looks like they are a few difficult areas on the block to spray with paint, so they probably got missed when the block was painted (see pic below). Not a big deal, a quick touch-up was all that was needed.
5) Some of the bolts on my old motor's intake were too corroded to use, so I replaced them with new grade 8s.
6) The oil pan gasket supplied in the gasket set for the motor was ok, but had the dipstick hole on the wrong side - putting in on the other way made it fit poorly, so I went and bought an appropriate gasket at checker auto that fit better.
7) The oil pan that I had didn't have an included windage tray... it mounted to studs in the old motor. I elected not to install it at this time, as I didn't want to remove and mess up the main bolts.. I am pretty sure I can pick up and install an oil pan with a built in windage tray in the future. For now I'll run it as-is. Comments?
Questions: Does anyone have a pic of the hose routing for the power steering pump? I can't for the life of me remember which was it goes, nor find an easy reference in my manual (seloc, I know.....).
Second, can anyone confirm that I don't need a restrictor in my intake gasket?
Here's the pics:
Bit of rust:
Oil pump installed with sump tube from old 305, that's Shawn and David helping:
Valve covers going on.. I'll do something about the labels later:
Intake on.. a bit more rust than I'd like, but we did clean out the passages to make sure there's nothing big enough to fall through to the cylinders:
Distributor and coil on:
Carb on and thermostat housing mounted:
So far so good. Tomorrow we'll find the other bolts for the water pump and re-verify we put it together right. Then I need to mount the transom plate and bell housing on the boat before I can put the motor in.
All in all, I'm happy so far with the rapido motor. I didn't expect to get so far so fast on this build, but thanks to my helpers we got a lot done in 7 hours.
Erik
