Re: Engine not starting
No voltage at the coil when ignition is in "On" but voltage at the coil when ignition is in "Start" (cranking) is a classic symptom of a bad (open circuit) ballast resistor or ballast resistor wire. Most ignition circuits that use a ballast system have a bypass of the ballast resistance when cranking.
I believe it is a wiring problem, or bad component in the ballast resistance circuit.
