Lots of ?'s about johnson 5hp.
F_R
Re: Lots of ?'s about johnson 5hp.
Hoo, boy. That one is going to be a challenge. I've drilled out many thousands of bolts, but that one scares even me. Good luck.
iwombat
I think you pretty much have to drill it out, but yeah that's gonna be a challenge. Might want to set a roll-pin or plastic bushing snug in the hole for a guide and start with a small pilot drill. Then, go to a larger left-handed drill and hope to spin it out.
4.0l sahara
If I can't get it out could I still use one bolt?:confused:
4.0l sahara
Do you think sears has left handed drill bits
4.0l sahara
I do have a seized 1960 3hp with a two blade prop would this fit it and is it a different pitch?
Also I need to get a impellor and lu seal kit. I would like to get these online if somebody could post a link to the parts I need that would be great.:D
iwombat
Even if you have to, you can drill it out, then heli-coil it all. The key to any of it is going to be getting a good center pilot hole going.
If it's too daunting you can always have a machine shop do it.
4.0l sahara
How much $$$$ do you think a machine shop would charge to get it out?:D
iwombat
I think my local shop would probably charge me $40 or so. Your mileage may vary.
4.0l sahara
So anybody know anything about the prop I have?:confused:
4.0l sahara
Could sombody help me with the ?'s I have in this post.:D
tmcalavy
Might fit, you'll just have to try it and see...should be about the same pitch as a two-blade prop for a 5 hp. If not, don't worry...they come up all the time for not much scratch on Schmebay.
F_R
3hp prop would be different. I don't have the proper parts book for your 5, but the 1968 model is on line at "http://epc.brp.com/default.aspx?brands=ej&lang=E Copy and paste the address without the " because we are not allowed to post links.
I would say that your motor and the '68 are about the same.
4.0l sahara
Are there any good websites that will have the parts I need?;)
4.0l sahara
anybody I want to try and order some part today.:)
tmcalavy
The Iboats store will have some parts for it. For what they don't have, try any of the outfits listed on the links page at www.aomci.org . I like Engine, Blade & Prop in Milwaukee a whole lot, good folks/good prices.
4.0l sahara
Would the seal kit for a 1955 to 1967 5.5hp be the same as what this motor needs?
