Re: Clear 2 part paint?
The clear over the metal flake may make it look better if it's not too bad, but you'll need to add enough layers to level the surface and then sand it smooth. The flake itself can lose it's color and gloss and thats not easy to fix, plus it can be blotchy and uneven looking when you're done. On the blue, sand it well and the clear will help some, but normally if you sand and buff it, it should last a long time without fading or losing it's gloss. Don't use the clear over the white, most clears tend to yellow and while you won't notice it much over metal flake and dark colors, it's easier to see over light colors and white.
