Re: Old Geyser Needs Help
I've taught a lot of new skiers how to get up on a slalom ski and this is my opinion. I learned to ski on a full double booted competition ski so I had to learn the hard way.
Tell the driver to give it full-tilt-boogie.
I like to be dragged at about 3-5 mph so that I can get the tip of the ski about 8" out of the water. Then I say "hit it"!
Make sure you keep your knees as close to your chest as possible held together with your arms straight and make sure the ski tail is against your butt. This will remove most of the vacume behind you and reduce the effort significantly.
Also I always start with both hands facing down and hold on only with my fingertips-don't close your grip-you'll loose a lot of strength if you do. Once I'm up, I change to a baseball grip.
If you do that, you'll pop right up without a lot of effort.
Good skiing!
Good skiing!
