In the Mercruiser owner's manual it does not go into wot. When at wot it is usually there for no more than 15 min.Only objection I can think of is that the gas gauge needle will travel at about the same rate as the minute hand of a clock, only the other way.
I expect it will heat up the outdrive though, maybe consider installing a shower on it.
http://cgi.ebay.com/ebaymotors/Merc...ryZ26455QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Anything on the subject of extended wot in your Mercruiser owner's manual?
Cleaning, of courseIn the Mercruiser owner's manual it does not go into wot. When at wot it is usually there for no more than 15 min.
What is the advantage of using a shower on the outdrive other than cooling?
