- Apr 17, 2002
- 70,527
Re: changing to thru hull exhaust
Ayuh,........ I never said I Haven't done It,.... I Have,... Quite a few times....
And,......
I Stand by My Statement.......
As stated by Riverjet,..... The Major Choke point on a SBC is the Exhaust Valves,+ the OEM Manifolds,....... Period.......
Without spending the Big Bucks for True exhaust Headers,......
Thru-Hull Exhaust is a Waste of Time,+ Money......
All it does is Pi$$ Off Everybody else who's boating or living on the body of water that You're boating on.......
Btw,.........
That's a Crock of the Smelly Stuff too.................
The Proper way to accomplish the task is to Remove the Y-pipe,+ install a Block-off Plate to the inner transom plate.......
Here's a set of 4, 1/2" Thru-hulls,....... Free Breathing,+ LOUD......
It took about 4 or 6 Tries to get them Quite enough to satisfy the authorities,...... Muchless Myself.......
They started out just Straight out at the transom,...... I added the Downpipes to get the outlets below waterlevel to Quite it at Idle.......
When I do it Again,+ I Will,....
The Downpipes will be Inside the boat.......
But,........
I'm Not kidding myself,....... There's Absolutely No HP Gains to be found with this.......
No, it's all in your head, that there's nothing to be gained. You can't make a statement like this, unless you've done it! and I have, more then once.Ayuh,......... And it All in Your head...........
And,......
Btw,.........
I'd recommend capping it off somehow, maybe a couple of 3" PVC one way vertical check valves. (water goes out, nothing comes in)
some people say capping it off causes a suction at the prop, which will slow you down.
But,........
