I have an 83 Jonson 115 V4 that has a ding in the lower stb piston. However,the cylinder does not appear to be damaged. I am planning on over hauling the power head myself, but I need a machine shop in there area to inspect and bore/hone the block if necessary.
Also is it necessary or recommended to replace the other pistons. Compression on the good cylinders was 105-110psi. I was planning on just replacing the rings on the good pistons and replacing the damage piston.
