Re: Why is it bad to use a trooling battery to start??
Thick plates not only tolerate vibration damage better, but apparently tolerate repeated deep cycling without damage better and that's why they are used.
Like stated in a couple of answers, deep cycles have thick plates so you can fit fewer in the given battery dimensions, hence less surface area in contact with the solution and consequently less peak current capability.....More impedance as JB said.
A trolling motor may run 40 amps for a big motor on full speed, whereas starting a large engine can whack 200 easily...there's the difference.
But a few years ago, I bought a 300 cubic inch diesel engined farm tractor that had a single battery for starting and it had obviously been there doing it's job and then some, for a very long time. It was a deep cycle, not combination start/cycle.
I was amazed. So I guess you never know.
Mark
