I have a 1964 650, 65 horse, that I just bought. I spent yesterday and last night reading old posts about impellers and water pumps but found none similar to mine. The impeller was replaced, by previous owner, but no water comes out of the telltale. When I put the muffs on I hear water filling up the motor then watch as it comes out around the prop, (not through it). When I start and run the motor it comes out what I believe is the reverse lock rod on the front edge of the motor just below the transom mount and tilt/trim. The head never got hot, warm to the touch, but only air and steam/smoke came out of the telltale. Should I drop the lower end or just try to blow out any clogs? I am wondering with the water coming out other places and the head not getting hot if it is a matter of pipes and hoses hooked up wrong internally. I have other questions but will post them seperate since they deal with other parts of the motor. thanks for the help, Elark7.
