Re: 1976 70 horse no spark
How did you determine that your kill circuit is "grounded all the time"? If the two "M" terminals on your keyswitch test positive for continuity at all except when the switch is "off", then you are correct, the switch is bad.
Otherwise you can rule out the keyswitch & boat wiring harness by testing for spark with the main harness plug (big red plug) disconnected. Turn the engine over by jumping the solenoid. If the engine starts like that you'll have to use the manual choke lever to shut it off - or just disconnect and ground the other two spark plug leads while you test one. If you get spark with the plug disconnected, troubleshoot the keyswitch, emergency kill switch (if equipped) and boat wiring harness.
Post your results.
p.s. The boat will run without a battery, but that'll fry the rectifier - meaning that when you put the battery back in, the motor won't charge it.
p.s.s. To jump the solenoid, use a jumper wire to connect the positive solenoid terminal (large terminal with red battery cable attached), to the input terminal (small terminal with red/purple wire - or is it a yellow/red wire - in any case, it's the one that *doesn't* have a black ground wire on it).
