Re: Using engine analyzer
If it has the clamp on type of inductive pickup, you can use it as an inductive tach as long as you do the correct math.
If the pickup was intended to go on one spark plug wire of any number of cylinder engine (4, 6, 8), then put the pickup on one of your spark plug wires and divide the RPM you see by 2. (the 4 stroke tach expects 1 pulse per evey 2 revs, you're giving it 1 per every rev)
If the inductive pickup was designed to go on the coil hi-tension wire, then set it for 4 cylinder, put it on one of your spark wires and multiply the RPM you read by 2. (the analyzer expects 2 pulses per rev, you're giving it 1 per)
If its not an inductive pickup and it was designed to connect to the output of the points, you may be able to figure out somewhere else to connect it but this will take a little more thought. Example: your analyzer, set for 8 cylinder, expects to see 4 pulses per revolution on a four stroke. If connected to the stator, and if you have a 20 pole stator, it's putting out 20 pulses per rev, so divide the analyzer's reading by 5. Make sense?
Good Luck!
