Re: crack in hull
Zell to fix it properly, you will need to get access to it from the inside of the boat. It likely means you need to cut out the floor, dig out the foam, grind the hull around the crack until the surface is clean and dry and then lay epoxy resin and cloth over the hole. I would double the original thickness of the hull with the repair. When that is done, replace the foam and floor and glass it ti make it water proof. Now fill the crack from the outside with MarineTex and sand smooth.
