180Diablo
- Mar 8, 2007
- 76
Just wondering how I would be able to tell if this is a possible loose/wearing out shifter cable or a normal condition and I need to just deal with it.
Boat im referring to is the one in my signature. 93 mariah, alpha I, Gen 2, 3.0L.
After letting my boat idle at the dock for a good couple minutes, lets say around 5 minutes+ or at least till it gets up to temperature, when I go to back it out of the slip, the odd time it will stall on me. Normally it stalls on me only one time and the second time shifting I have no problems. Once I have switched into reverse and then switch to forward and head out for a few hours its seems fine. It hasn't stalled on me when coming into dock, however it sometimes seemed like it would stall.
When I was last up there two weeks ago, I tried to watch and listen to the motor to see what rpms the motor would cut out at when attempting to shift to neutral then to reverse. From what I saw, this would happen when the rpms drop below 1000 to around the 700-800 range.
If I let it idle around 1000rpms and shift fairly quickly before the rpms really have a chance to drop off, there is some grinding that I hear, but it does go into reverse without it stalling. Yes, I know grinding equals bad and thud equals good and to shift it as quickly as you can without over-throttling and throwing your passengers into the stern.
Complete engine tune-up was done in May, gimbal last year, outdrive oil serviced. Besides a carb rebuild a few years ago (boat sat winterized in storage from 04 to 06) and whatever my marine mechanic has done I am unsure on any other work being performed on the boat.
So what I was wondering was, am I possibly fighting something that needs to be replaced / looked at OR is it something that is normal and it's just me that needs to work on his shifting skills to prevent stalls. Is there any in water checks that I can perform with the engine off to listen for or to see if its shifting properly?
Not mechanically inclined enough to remove the outdrive to do a check that way. Checking oil and looking for problems is about as far as I go.
thanks for any help/replies
