140 looper at 6000rpm
reeldutch
the motor is a 87 smallbore rebored to accept 88 big bore std pistons.
timing set at 18* give or take 1*
compresion is 130 on all 4
prop size 13 3/4 X 17 sst
wot rpm 6000 (teleflex tach)
speed 40 mph teleflew speedometer
humingbird fishfinder with wheel 41mph
prop slip is:
40X1056
---------- X100 = 83
3000 X 17
so my prop slip would be 17 %
is this correct?
72SideWinderSS
Re: 140 looper at 6000rpm
Try,
(Pitch X RPM) / (Gear Ratio X 1056) = Theo Speed
(Theo Speed - Actual Speed) / (Theo Speed) = Slip
Don't forget to add an inch to the pitch for the cupping.
reeldutch
so if all the imputs are acurate the prop slip is 17% wich is a little sloppy.
the motor is mounted on a bracket with a 4" ofset and the antiventilation plate about 1.5" above the keel.
i just think that it could be the hull or prop causing this slippage.
just want to get it running as fast as posible
i realize for better economy i should run a 4stroke or dfi engine.
reeldutch
reeldutch
oh yeah its on a 1973 20' mako center console
ezeke
Did you try it with the a/v plate any closer to the keel?
reeldutch
ezeke you mean dropping the motor?
i believe it would drop the rpms a little.
i'm just curious in how efficient a older hull can perform. should i just be happy with about 17% slippage.
i did some calculations and if i get it to 8% i would only gain 4 mph.
i just might try different props see how it does.
