1974SeaKing15HP
- Jul 10, 2007
- 1
I have a new 1974 (Serial number is 47x....) Sea King 15HP outboard. I found it in my parent's basement laying on it's side. In all likelyhood it's been that way since purchase.
It is brand new, not a spec of dirt inside the cover. Probably started once or twice if that. I pulled the spark plugs, one is clean, the other has corrosion around the tip.
PROBLEM. I can not budge the motor by pulling the start cord. I am 27 and lift so it's not an issue with strength. The thing will not budge. I don't know a lot about marine outboards so I took off the nut on the top of the motor and could not take off the top cover. I quit there.
Any advice? It can't be seized... Thanks.
