Re: Pressure test a Lower
Pressure testing a LU is done to ensure all the seals are good or to find bad ones. The way it is done is to drain the LU of oil and then hook up an adapter to an air supply with low pressure in it (~10psi I believe) and then listen/look for any telltale leaks at all the seals.
