Speakrdude1
- Jul 9, 2007
- 10
Hey All. I had to re-register my screenname for some reason. My old password wouldn't work any more. I tried over and over to get the "email me my password" thing, nothing, nada. So, same screen name with a 1 added. Now I am a "New User" again!
So anyway, I have added the Thunderbolt IV ignition system to my 70's model GM 350, 10:1 compression engine. Just in case the Mallory electronic (still with Mechanical advance timing) was causing part of my lean condition.
While I have the base timing at 700 rpm's at 8 degrees BTDC, the max advance does what it is suposed to do which is max advance of 32.
When I set the timing to 8 degrees BTDC at idle, it really wants to slow the idle speed down, hopefully its not laboring to much.
But it is a tiny bit slow to start when warm. Other than that, it runs great. Real crisp acceration. Good hole shot, for a 6000lb boat anyway.
Should I leave the timing alone now and focus on the idle mixture? I had it set pretty good with the old Mallory ignition.
Is there any possibility that the old 70 model GM 350, with high comp heads, flat top pistons (truck engine, I believe) needs 10~12 degrees at idle and a max curve of 32 or less?
Maybe one of you more experienced guys know of some older specs.
Thanks
Jim
Thanks
Jim
