i've got an issue that perhaps someone could help me troubleshoot as at this point i'm not seeing things clearly due to an overheating temper. on the advise of a few knowledgeable friends and a mechanic at my yamaha dealer i installed a fuel water separator; my vst filter was clogged last week and i had to manually clean it as the yamaha dealer i go to had none in stock so i thought it wise to add an additional layer of protection. i installed the water separator this afternoon and made a mental note not to leave the dock until i ran the engine at idle for around 15 minutes, good thing too as after around 10min of running at idle the engine konked out. I was able to restart the engine 3 or 4 times and each time it ran rough staggering a little not its normal self for about 10 secs each time and then died, after about the 4th time she will not start the engine will turn catch for a millisecond and then sputter out. i thought aha i know what i'll do i'll bypass the water separator with a brass union fitting joining the fuel line and this should fix the problem because this was the last thing that was changed with the setup and this appears to be a fuel related issue. i'm not getting of that easy after i did this the engine still will not start, if i put it in neutral and give it 3/4 throttle she'll periodically catch run for a few seconds and then die out. at this point i'm not at a complete loss as i'm going to regroup tonight get my wits about myself and attack again tomorrow but if anyone has any tips or pointers they would be very welcome. this is what i plan on doing tomorrow:
1. take off the fuel filter and dump the contents into a clear container just to ensure that there is no water present
2. change my plugs, not necessary but they need changing anyway
3. change the vst filter
any input is welcome
brian
brian
