nightvision
- Mar 7, 2004
- 252
Hi all,
I have a Shorlander trailer with Bearing Buddies. I'm new to trailering so here are some questions.
a. When greasing the the bearing buddies, does the grease go all the way to the outer bearing, into the spindle, and then to the inner bearing?
b. Is it correct that I should apply one or two squeeze in the zerk before every trip out?
c. To check to see if I have positive pressure on the bearing buddies I just need to press lightly on the diaphram and should feel some give. If this occurs then I'm OK. Correct?
Thanks.
Thanks.
