This is for a friend's '89 Starcraft 18SS re-powered with 2007 Merc Optimax 115. It had an Evenrude 70. The 'rude would top out at 30mph gps at unknown rpm with (I think) a 17P 3-blade aluminum prop.
Goal is to improve the boat as a ski, tube, and all around family boat. In that order.
I think this aluminum boat weighs something like 1200 lbs plus motor and gear. The dealer repowered it with the Opti 115 with a Merc Laser II 19P 3-blade SS prop. After break-in, the package is a total dog. Goose it and it takes ~20 seconds to get on plane. It maxes out at WOT @ 4500 rpm at 38 mph with 600 lbs of bodies and a 10 gals of fuel, a long run, and trimmed up to get max speed. Max rpm on this engine should be in the 5300 to 5700 range, if I'm not mistaken.
It seems like this motor should be able to pull a 19P. We are going to try a loaned 16P 3-blade SS tonight to see what happens -- weather permitting.
The owner is very frustrated that this new toy performs worse than the original 70 HP 'rude. It would deep start a 200 lb slalom skiier. I wouldn't even want to try on this new engine. It would completely re-define the medical procedure known as a nasal flush.
I'll report back.
If anyone has any suggestions, I'd like to hear them.
I'll report back.
