Hi! Wondered what you thought about my problem. Got a 1975 Sea Ray with a Merc 888 only 500 hours on the reman engine. Rochester 2GC carb. Changed out the water sep filter a week before I rebuilt the carb two weeks ago. Went out first weekend after rebuild-she purred like a kitten all day! Sweet! Went out the next weekend and rode around for a half hour or so, everything was fine! Then all went bad. Started backfiring on acceleration. Doesn't do it at idle but when I accelerate or when I'm going full speed it backfires. I've pulled the top off the rebuilt carb and checked for water and dirt and all seems OK. I checked carb filter and it looks new because it is. Plenty of pump delivery pressure, replaced it last year. New valve cover gaskets this year, everything looked clean and new under the covers when I replaced the gaskets. I'm planning on replacing the filter again tomorrow and trying a test run with the cap loose to see if maybe my vent line is clogged or restricted. Any other ideas?
Thanks!
Thanks!
