Hi guys, i will try and do my best to explain my situation, please try and bear with me. I just bought my first boat, its a 1994 17 foot maxum with a 120 hp force on it. Yesterday my dad and i took the boat to a mechanic friend and we couldn't get it started all day. We believe the engine keeps flooding itself. it is getting spark and fuel. Today we redid the battery connections because they were pretty bad and put a new battery in it. It took us about an hour to get it started but we finally did by spraying some ether(sp) starter spray into the top carb. It fired up and we let it run for awhile. Upon cool down it would fire right back up without having to give it gas. So what we did then was take it down to the lake and we ran it for awhile. It ran alright, with me and my brother in it i got up to about 41mph trimmed. Does that sound right? I would think a 17 footer with a 120 would go faster but idk.
After about 20 minutes of test running it, i tied it up and let it sit for about 2 hours. After that i cuoldn't get it started again. It would just flood it self. I tried removing the sparkplugs, airing it out and then trying again but same outcome. I had to have it towed in. If you guys could please give me some things to walk through and check i would greatly appreciate it. Someone told me that the starter might be drawing too many amps and not giving enough spark to the plugs to ignite all the fuel. is that possible? It's very confusing to me beacuse when i bought the boat the engine would always fire up great and easy. Also one last thing, when i pull the plugs out to air it out, i would crank it over for a few seconds to blow everything out of the cylinders but i noticed that gas would mist out of only 1 cylinder. the 3rd one from the top. Why would it only come out of that cylinder? Could i have a problem with my lower carb? Thanks guys
