I just installed a new alternator for my 87 Merc 170 (it already had the aftermarket charging, I only replaced the alternator), and now I am getting sparking at the battery terminals.
There is more to this story. I am also trying to test the compression of my cylinders so I have removed the plug wires and the center coil wire, and the the electronic ignition plug.
When I go to crank the engine, the engine does turn over, however you see itermittent sparks on the + and - battery terminals.
Anyone ever see this before? Did I screw something up. The alternator is a simple single wire 63 amp v-pulley.
Thanks!
Thanks!
