Re: evinrude 9.5 sportwinn
The rear screw's hole taps into the water jacket. You probably just need to put some goo on the screw. There's also a rubber gasket under the recoil unit that caps off a hole into the water jacket. You could be leaking there too.
As for getting that screw out. Penetrating oil and heat are going to be your best friend.
