Buzzbait Delima
BULLWARKS
Hi all,
Anyone have a problem keeping your BUZZBAIT from running with the head and skirt under the blades?
Mine seem to keep flopping over so the blades are on one side or the other!
rndn
Re: Buzzbait Delima
Are you tying them on or using a swivel?
rndn
Re: Buzzbait Delima
I disagree about using a swivel. I've found that a swivel creates quite few mis-casts. Even though I use a wire to keep the swivel in place, it tends to get caught up in the baldes of the buzz bait. The best buzz bait I have is a two blade model that has a small foam float above each spin blade. Never had a problem with this particular buzz bait. Thanks for the comment about a nice boat, I just got it a couple of months ago. So far I really love it.
CN Spots
Re: Buzzbait Delima
It's probably just out of tune. Next time you use it, twist the metal arm above where you tie on so that the blade runs at a slight angle to the hook. If that makes it worse, bend it the other way. If neither works, buy another buzzbait.:D
spots
BULLWARKS
Re: Buzzbait Delima
Thanks for all the replies. I'll try.
I have a Crestliner too and LOVE IT
