Re: Mercruiser 4.3 problem
Need more info: Year, Fuel Injection, ...etc?
What you are describing can be a large list of things. If you don't want to take it to a Marine tech then you are best starting with the basics and least expensive. Had a similar problem with a 4.3 Merc which ended up being water in the tank. Dumped water separator/filter into a clear container. Watched for water fuel separation (fuel goes to bottom). Found out it was nearly 100% full of water.
Then again I had as similar problem with my Volvo Penta 5.7 EFI. Ended up being a bad connection at the main engine wire harness connector. Started out by replacing the filter though. Then went looking for lose connections. These sort of problems take patience and strong troubleshooting skills and logical thinking. Got to list out all possibilities, then start eliminating each item starting with the most likely or least expensive (connections, filters). Some things you can test, some things you can check. You may end up with a few items that you can't test and may have to start replacing things.
Take what you get here as "suggestions". The most you will get is and educated guess, as long as you have educated us
Meaning, give as much info as you can (equipment information, all symptoms), leave out what you think the problem is.
