leakdoctor
- Jun 22, 2007
- 4
I just bought a fixer-upper. 1989 Glastron X-17 with a 3.0 mercruiser. The guy says he's had it for two years and it ran fine. This year he got ready to run it and the starter bumps, but it won't turn over.
Their is no water in the oil. Pulled the valve cover and the top of the head looks fine, no metal shavings on the rocker arms, etc. No rust on the spark plugs. It has a new starter on it. I've tried putting it in gear and turning the prop with a pull handle. No luck.
I've been told that something could be locked up in the outdrive. So I am going to pull it off tommorow and check it. I removed the spark arrestor and looked down into the carb. I can see rust on the top of the throttle plates, and opening the throttle I see rust in the bottom of the manifold. The way the boat is designed water running off of the cover in the back would drip right onto the falme arrestor on the carb. So rain water could run right into the carb. I have removed the spark plugs and injected PB3 into the cylinders.
I recently bought an old tractor that had gotten water into the engine and caused the rings to stick. I pulled the injectors and put PB3 into the cylinders. After sitting 24 hours it freed up and now runs like a champ.
Anyone ever had any luck freeing a seized 3.0? Any suggestions?
Thanks
David
Thanks
David
