Great day, boat in water, outdrive stayed in up position
Back home opened the out hose to release some oil (just a few oz.) and the drive comes down normally with the pump. When I bring it up till it physically stops the drive is stuck again. If I bring it up just 1 inch below that, it goes down without probs. Disconnected the trim cylinder to move the outdrive manually up and down and could not feel any resistance. Pump sound higher when it goes down then when it goes up.
What could be the problem?
Is there an easy way at the ramp to bring the drive up/down without bleeding? It's a 2003 3.0 Mercruiser with Alpha One outdrive
