4.3L LX Alpha 1 was professionally winterized last fall. All was fine last time out last fall. In the water for the 1st time this weekend. Started up fine, but after about 10 minutes running it started to die at full throttle. Runs fine again when throttle is backed off and engine is under about 3000RPM. Starts fine and runs fine under low-med throttle. Once engine is cooled down, everything is fine at all RPM and throttle ranges - but problem repeats itself when engine heats up. Boat was stored for winter with full fuel tank and gas stabilizer. New fuel pump last season. Anything that might have been done as part of winterizing process that may have caused this? Suggestions as to what to try first? Thanks.
