Re: tilt problem
I know of no manual method other than disconnecting the rams at the rear pin so at least you can trailer it with the drive tied up. Make sure you have enough fluid if the trim unit runs but doesn't lift. Check your Up solenoid if all you hear is clicking. Check your switch if nothing happens at all (could be the Up solenoid too).
